1 Attachment(s)
rpm cut off comes up before the 2>3 shift , wont shift
Hi, ok heres my problem , set up a tune for my friends 98 TA , mostly just worked on the tranny, i swaped his gears from 2.73 to 3.42 , in the tune i put in correct tire diameter and gear in speedo calculator to set the correct pulses per km H0101 and output shaft revolutions H0104 but when we hold it at wot the 1>2 shift happens but the 2>3 doesnt, the cut off comes first , i did not change the wot shift points in the tune so i dont understand , if i am missing something why does it do the 1>2 shift or is it just boarder line and the difference is more apperant with the 2>3 , did not try the 3>4 but probably is the same , does this have to do with the the (shift point correction tab), does this have to be set because of different gears , i thought with the correct pulses per Km and output shaft revs it would be ok , isnt it supposed to shift a wot as set in the shift points , i am sure i am missing something , i tried for the hell of it to make a new tune using the ( shift point corrction tab ) in speedo calculator by entering tire diameter and old gear and new gear but when i click apply it tells me i have to enter a non 0.00 percentage value and that is where i got lost but that may not even be my problem , i attached the tune,Attachment 11057 thankyou in advance, Eric
