Lots more limiters, lots more transmission tables, and several other important tables. :) woohooo..
Also a speedo calculator that is Awsome!
I will be installing this weekend and see what's available.
I assume the additional parameters, tables, and limiters are available for the LL8 using the V1 cable. I never upgraded to the V2 because of the lack of updates for the LL8.
Ive got it downloaded and running on my desktop where I make tunes and then on the laptop where the tunes get flashed from.
I like the limiters section better now, and the manual hold 1-2 and 2-3 trans tables are nice too. I dont have a desire to set them to anything but the stock settings, but for some they will really help out.
The general transmission segment with the gear ratios is a nice add too.
The only thing I want to do is be able to remove the RTACS screen from above the general description. It does nothing for the LL8 except make it so I have to adjust the size of the desc box which then I cant see all the tables below. Just something that can probably be turned off that I havent figured out yet.
