Is there any list of where table names are located at?
example
B3604 = Engine Cal > Fuel > Crank Start > Commanded Fuel When Cranking
In my searchings I see things going by that number(understandably), and I sometimes find it hard to find them.
example
You can enter the number in the Tune Tool and "jump" to that spot. The path in the tree is then apparent.
You can also designate tables as favorites, making it easier to find them later.
Do as gto_in_nc said...
use uppercase on the letter (e.g. use B3604 instead of b3604) to find the table itself,
otherwise lowercase finds all references to that table.
Ahhh. I never tryed using that search feature, didnt know what it was for.
How do I add one to favs? I see how to delete, but not add.
Directly under the "Search" button is a blue button with a plus sign in it...
Thanks Jocar, I did not know about the search using capital letters, I was going to ask if there was a way to only search for tables a few weeks back and that has answered my question :cheers:
Must only work with an authorized copy. I have them demo one at work still and that didnt work.Quote:
Originally Posted by gto_in_nc
The demo software and the authorized software are the one and same...
Can you post a screenshot...
