Is there any way that the scan tool could capture exhaust temp on the 6.7L in the logs, so that one could make a map of it versus fuel rate, air flow and equivalence ratio ?
Yup, you'll be able the EGT probes the truck already has for post turbo temps or you could use a pre turbo thermocouple and use the connectors that come with the V2 and run it as an external sensor.
Could you move the OEM sensor pre-turbo? If so, would there be any benefit to it?
I talked about this with Ross.
The problem with doing that is the length of the probe. It's longer than a normal probe that you'd see with an EGT gauge and will bottom out if you try to use it pre-turbo.
That solves that I guess!
You could do it if you wanted to mess with a few adapters to add some height, but for what it's worth, it's just as easy to run an external probe to the V2.
Is there a fuel limiter map based on EGT ?
That would be a really neat way to tune if there was !
I'm sure there is, but it's not one that we've seen yet.
That's not really one that you want to "tune" with persay, that's more of a safety backdown.
There will be points that you'll hit higher temps and then they'll drop, especially if you're using larger chargers.
It would certainly be a good limiter for a tow tune with a stock exhaust though.
