If I need to disconnect my battery for a wile or if it dies one night will I loose my tune, will it go back to stock?
No you will not lose your tuning. The tuning onced flashed to the ECM will be considered the same as if it was a stock programming. So lose of power will not make a change. When flashed you have overwritten the same items the tune took in the first place.
Brian
