Re: Delivered Engine Torque
Quote:
Originally Posted by daveb
I have been scanning delivered torque for calibrating my shift speed changes and I have not seen the torque much above 150 Nm.
When using this to calculate flywheel torque the best I can get is 140kw.
This seems to be less than what I expected.
I have 221 rwkw.
Any thoughts?
DaveB,
You don't happen to be driving a Ute do you??.
You can pretty much ignore that value on Utes, GMH screwed the cals to use that Torque figure for other things (like slowing the F.Pump down at WOT).
Using the navigator in the tuner take a look at parameter number 'B1904'.
