1 Attachment(s)
Limits Not Being Respected
Working on a cax to add fuel gauge driver PWM frequency adjustment to 98-99 blackbox PCM's. I think I've basically got it figured out, but I notice the MinLimit and MaxLimit I've defined are not being respected once the parameter is loaded into EFILive. The MinUser and MaxUser do however seemed to be respected. I can still enter values higher than these "EFILive limits" and they seem to stick, but maybe they would be clipped during flashing? Have I done something wrong in the cax file?
Code:
[F1036]
; Description
DESC.001 = PCM fuel gauge driver PWM frequency.
DESC.002 =
DESC.003 = Stock frequency setting is 59.5Hz. Lower frequency settings may result in fuel gauge needle hummingbird or buzzing effect.
; Seg Caption Major Minor Vis Dis 2D Grp
VIEW = 6 "Fuel Gauge PWM" "Fuel Gauge" "" 1 1 0 2
; Address(es) BitOff Bits Typ Inv
ADDR = E6E8 0 8 UNM 1
; Unit Symbol Factor Offset Prec MinLimit MaxLimit MinUser MaxUser
SI_SLOT = Hz 0.00019098548 0 1 59.5 210 59.5 180
; Body Col Row
ULABELS = . . .
; Enumerations
SI_ENUM = .
IM_ENUM = .
; Unit Symbol Labels
SI_COL = . .
IM_COL = . .
SI_ROW = . .
IM_ROW = . .
