1 Attachment(s)
2016 LML injection timing ?'s
Wondering if anyone has any insight on actual injection timing. The issue seems that my data is reading higher timing than commanded. In All my timing maps (made them all the same) the timing at say 35 mm3 and 1350 rpm my maps are at 2 to 3 degrees. When at idle which matches at 1 degree as soon as I hit the throttle and rpm comes up it quickly ramps the timing to 8.5. This is no where in any of my maps. Is it possibly adding pilot 1 and or 2 to base as you throttle up ? Here is my map which is now running pretty good. It rattles just a bit more off idle up to 1500rpm and when I noticed the timing ramping up that quick I assume that is why.
Here is the map.
