Injector test
I seemed to remember there was a option in EFI live to do a injector test like the dealership does. Something about commanding 160MPA and reading what it actually was.
Not looking for the injector balance rates.
I might have another set of bad injector due to P0093 popping up since the warranty company would only replace 3 of 8 injectors but I recieved the code again when passing someone. I just cant find the link again.
In scantool:
- connect to vehicle,
- click DVT tab,
- select controller (LB7 Diesel),
- click Control subtab,
- click Activate,
- checkmark Activate Individual Injector Control,
- click on the injector you want to turn off, be ready to click All On,
- click Deactivate when all done.
I don't know diesels, so make sure you know what you're doing.
I thought there was another one that didnt turn the injector off but commanded the rail to 160MPA and read what pressure it went to or held.
the fuel pressure contol is right above the injector control in that tab
