Would someone check this out and make sure I'm not doing something stupid. My timing table looks realistic, and the numbers appear to be safe. From the best I can tell it works, but I was wondering if someone could bump it against their own calculator to make sure. You will have to change the file extension to .xlsm, otherwise the forum wouldn't let me upload it. If any one wants to feel free to use it. You can change the data ranges to whatever you need them to be, only if you change the size you will need to update the code if the table needs to be larger. Its specifically for the LBZ-LMM right now.
just copy your fuel pressure into the top table and the injection pulse into the second table, set your percentage next to "split" (the gray square auto-calculates) and click time it. Then copy the bottom table.
Attachment 13797
Thanks in advance
JT
