I have a 08 csp5 delete tune that was done by a reliable company pm and I'll send it to you
Sent from my iPhone using Tapatalk
I use Insite to do any delete on Cummins motors. Once you make that part of your tune in Insite, you take that file into EFI Live and tune it for performance from there. Pretty simple to do, its just getting a working version of Insite, because unfortunately its not easy to get. I would say do some searching on Google, but I know your going to be over run with virus. If I were you, I would speak to your tuner to see if he has a copy he can give you. Insite is similar to EFI Live but it is its own beast of a program and figuring it out isn't easy. BUT you can find guides to show you how to turn off everything you need to do a delete on a Cummins.
I use insite on my trucks. Just put a high sulphur tune in and bump the hp
as for Insight, this sounds really interesting! if i could get a legit use able copy of tat software then ill definitely get a new truck!
I don't play around to much. I buy tunes from ppei or motor ops
