No Analog is fine. Its just with the V2 Serial is a breeze. Your Pid list has both Serial and Analog selected..:confused:.
Its the Open-Loop that is the problem. If your are doing CALC.VET you need to be in closed-loop. Perhaps your WB is off because you have are open-loop with both your MAF and VE Table enabled. You can't do that.
