EFILive on an 05 Chevy Colorado?
I wanted to try out V7 and V6 on my new Chevy Colorado to do some logging for fun and maybe use it for some future mods. Problem is that it wont log data. It connects fine I can update pids and mods, but when I hit F3 to start logging it gives me an error message. $31 Request out of range... I have checked all of the pids and mods. So is it just that EFILive will not connect and log from my colorado or am I doning something wrong or need to change some setting?
Help
PS: attached is the bug report from V6... V7 gives me the same thing
Error report generated by EFILive at 14:05:12 on Feb 02, 2005
Error code: ERR_RESPONSE/5
Response $31: Request Out of Range
EFILive Version: 6.4.1 (Build 60)
Platform: Windows XP
Version: 5.1 (build 2600)
Processor type: Pentium 2791MHz
Directories
Temporary Cache: C:\Program Files\EFILive\ScanToolV6\Temporary cache
Logged Data: C:\Program Files\EFILive\ScanToolV6\Logged data
Customers: C:\Program Files\EFILive\ScanToolV6\Customers
Configuration: C:\Program Files\EFILive\ScanToolV6\Configuration
Exported Data: C:\Program Files\EFILive\ScanToolV6\Exported data
Images: C:\Program Files\EFILive\ScanToolV6\Images
Sounds: C:\Program Files\EFILive\ScanToolV6\Sounds
Maps: C:\Program Files\EFILive\ScanToolV6\Maps
Pids: C:\Program Files\EFILive\ScanToolV6\PIDs
Virtual Dash: C:\Program Files\EFILive\ScanToolV6\VDash
Print Reports: C:\Program Files\EFILive\ScanToolV6\Print reports
Bug Reports: C:\Program Files\EFILive\ScanToolV6\Bug reports
Connected: Yes
Com port: 5
Com setup: COM5: 115200,8,N,1
Requested baud rate: 115200
Cable id: 2
Cable code: ATV2 or ATUSB
Cable desc: B&B Electronics AutoTap cable
Cable version: 2.0.4
Cable Firmware date: 20030312
Cable model: AT1
Cable Serial number: 000026848029
Protocols: 0
Protocol list:
Auto connect: Yes
Scan OBDII info: Yes
Error retries: 1
Retry delay: 10
Message throttle: 0
Most recently used VIN: 1GCDS196858xxxxxx (Note: 1)
PCM information
PCM HDW Number: 892876304
End Model Number: 12596784
Serial Number: 4258KÃ*ÿGÿ006
Operating System Software: 12596785
Engine Calibration: 12586421
Engine Diagnostic Calibration: 12596808
Transmission Calibration: 12595358
Transmission Diagnostic Calibration: 12586396
Fuel System Calibration: 12597234
System Calibration: 12597240
Speedometer Calibration: Unknown
Operating System BCC: YKWJ
5x24 scan mode: Not supported
10x24 scan mode: Not supported
Maximum dynamic packets: 16
Detected modules:
$10=Engine controller
$28=Brake controller
$40=Integration/Manufacturer expansion
$58=Restraints
$60=Driver information/display
$80=Entertainment/Audio
