Quote: Originally Posted by trona I was wondering that myself and in that case would you need to map all the voltages instead of a formula? Thanks Dave If there's no formula/equation, then the x/y value pairs can be put into a "lookup" table.
Quote: Originally Posted by joecar If there's no formula/equation, then the x/y value pairs can be put into a "lookup" table. Is that done in the calc.pids text file or is it done in the scanner software?
Quote: Originally Posted by statesman Hi Joe, Can I point out that trona specified "non linear wide band output" in the original post. Oh, I failed to notice that, thanks.
