calibration problem
just bought efi live for my 06' 5.9l, this is all new to me.installed software, did the read, and on calibration down at bottom of page has three things with triangle and ! saying enabled. i have no tune yet, is this the problem? it reads my vin, ecm/CM849, CMB, calibration ID 35325553AS, pls some help? try to do a cal- flash CMB no supported?
If possible can you post a photo of the screen?
You have to full flash the cummins controllers, if you have errors on the calibration screen of the tune then your tune file is likely corrupt. If it says "incomplete do not flash" it likely has had a bullydog on it and a new file will be needed.
