Read posts in search...read tut..LM1 help.
1. Can't find which wire from the LM1 is analog2 White or Red?
2. Selected pids lm1-1, lm1-2, ad1, ad2 and they are shown as not supported...right click info gives:
" Factor = Calc.AFR_LM11.AFR / GM.AFR is not valid because requied parameter Calc.AFR_LM11.AFR at position 20 is not selected"
What does that mean? How do you select position 20?
3. Any reason not to hook the LM1 red wire to Pin C, White wire to Pin E and the ground to Pin D just to see if red or white is analog 2?
4. Analog 2 is set to 1v = af10, 2v =af20.
Thanks for the newby question help.:beer:
