How long is the cable? Doesn't look extendible... Is able to be permantently installed?
How well does it work with autotuning?
Hey Eric, Glad you see you back!! I'm running one on my truck with the STS, it's not permanent, but its behind the turbo, about 4 inches and the cables just run through the weather striping on the pass side rear door. I did lengthen the wires to get them to the flash scan box and also the power wires. It was pretty easy though. I have been very happy with mine, works great with Auto tune. I too am running COS3.
On a side note, I hope to see you back on performancetrucks.net. We need more boosted guys on there ;)
I've got one on my SS right now. Have it installed in place of the NBO2 on the passenger side. Works well there for me. Had to extend about 6' of wire to get the wires into the cab (routed into passenger area of engine bay, wired across the top of the firewall and enters the cab through the door jamb).
I've got mine in my SSS as well. It's mounted in the rear drivers side o2 location with the wires run up the frame rails and into the cabin behind the master cylinder. I have all the wires tucked up under the steering column with just a pigtail out to plug into the FS box.
