just had a chance to go out and try the menus under recording not paused and yep there the choices were. didn't have a chance to do any driving and allow for emulation tuning but I should tonight
ran into another road block. RTACS is only adjusting in column 15 kpa not sure what I did but im guessing I selected something to lock into this. scantool shows recorded data all over the map.
Are you logging the same Pids as the labels on your B0101 table? e.g, SAE.RPM , SAE.MAP.
yes, just double checked and its correct as you have listed.
I though maybe I blocked them when I was trying to figure out why I was unable to select filters but from what I read it would have a white back ground for the cells if blocked
http://i307.photobucket.com/albums/n...r/tune/pid.png
http://i307.photobucket.com/albums/n...r/tune/ben.png
just took this to show it stays in the 15 column only maybe one of my settings is off?
http://i307.photobucket.com/albums/n...litter/map.png
Is everything ok in you cal_link.txt file for B0101.
Im not sure I understand what that is.
Search your computer or look in program files / V7.5 / configuration.
Mines like this:
; Default ROW/COL layout for most LS1 operating systems
[LS1]
;Main VE Table
B0101.ROW=SAE.RPM
B0101.COL=SAE.MAP
B0101.RRR=CALC.BEN1,CALC.BEN2,CALC.BEN_AUT1,CALC.B EN_AUT2,CALC.BEN_FJO1,CALC.BEN_FJO2,CALC.BEN_LC11, CALC.BENLC12,CALC.BEN_LM11,CALC.BEN_LM12,CALC.BEN_ PLX1,CALC.BEN_PLX2,CALC.BEN_TE1,CALC.BEN_TE2,CALC. BEN_WBC1,CALC.BEN_WBC2
when I did a search for cal_link.txt it comes up with two note pad files which are just a list and shows
[LS1]
;Main VE Table
B0101.ROW=SAE.RPM
B0101.COL=SAE.MAP
