Hello.
I get this message when starting my FlashScan V2.
"*.pmm file incompatible with this firmware"
What does this mean?
Hello.
Download/install V7 and V8 software from here: http://forum.efilive.com/showthread....te-Nov-21-2013
Then using V8 EFILive Explorer, flash the bootblock and firmware into your V2.
Then using V8 Scan&Tune, configure BBL (edit pidlists and controllers to suit your ECM/TCM/PCM), and Program to V2.
Thank you for fast answer Joe, it worked.
Now I have another question.
I would like to use FlashScan to log an carburetor car with my Innovate lambda and get the rpm from the MSD ignition.
The lambda works fine logging with Scan Tool, but this is a dragracing car and I like to use the FlashScan only.
Any suggestion.
FlashScan requires to be able to log data frames from an ECM in order to log serial comms wideband lambda...
FlashScan can display serial comms wideband lambda without logging, but it is just displaying it (not saving it to a log file).
I see. :(
