1 Attachment(s)
Is this OS supported by EFILive?
2007 A40 TCM, OS is 25821031. When I fire up the scan tool, it connects but doesn't do the "Validating somethingorother" scrolling bar routine that it does with my A46 TCM. When I select the PIDS for Battery Voltage, Throttle Position, and Delivered Torque and start monitoring, it gives me an error that the throttle position PID is not valid. Also, it just reads "0" for delivered torque. Only the battery voltage gives a reading. With my A46 TCM (OS is 24259900) I get valid data for all of those PIDS.
If this is a valid OS for EFILive, then it means the TCM isn't recognizing my throttle inputs, so I need to go to plan B.
Here's the tune file:
Attachment 13126
