EDIT: This problem has not been solved with the latest update, please don't attempt to program any 2010 model 6 speed TCM's until we announce a fix.
After many hours of testing and lots of late nights, pizza and caffiene I believe the T43 reflash fault has been fixed.:fluffy:
The fault was only in the FlashScan/AutoCal firmware so to fix it all you need to do is to update your FlashScan firmware with the firmware (V2.06.17) attached to this thread.
The AutoCal firmware has not been updated yet, but will be shortly. Once it is updated it will be added to this thread.
If you encounter any problems with this new firmware please post in this thread.
Instructions:
- Save the attached file into the folder: \Program Files\EFILive\V8\Firmware.
- Connect FlashScan to your computer via the USB cable.
- Then start EFILive_Explorer, that will automatically start the EFILive Control Panel program (i.e. EFILive_Hapi) which will detect the new firmware file and display a balloon tip indicating that updated firmware is now available.
- Click on that balloon tip (or on the FlashScan icon in the system tray if no balloon tip appears). That will cause the EFILive Control Panel to be displayed.
- Select the Firmware screen and click on the [Update] button.
