Wish we would have gone metric a long time ago, like back when I was in college. It's a lot easier than Imperical!
Works fine in metric.
There can be some WIERD stuff logged as peak values. Not sure if it is an Edge issue or not, but I know that they stopped recording things (in "records") like max EGT and Boost due to erroneous spikes to what would seem like about 4x normal...
Again, I'm not sure exactly what signals the Edge intercepts, but Desired Pressure should not fault, Actual may get 'altered'.
I'll get my new gauges on and retry it.
70000 psi is like 482mpa why so high i geuss when i thought a couple mpa was lots but now.....wow:master:Quote:
Originally Posted by DURAtotheMAX
