See post #4 of this thread, courtesy of LastCall, thanks: Difference-between-Direct-and-Learned-Idle-Airflow
Calc-MAFT-correcting-VE-and-calculating-MAF-(in-single-log)-gt-reverse-of-Calc-VET
Calc-VET-correcting-MAF-and-calculating-VE-(in-single-log)
Which-IFR-calibration-to-use-Corvette-LS6-or-Bosch-28-8-58-PSI
Interesting-info-on-B3702-Injection-timing
LC-1-free-air-calibration-from-FlashScan-V2
06-Vette-LS2-440-CI-Auto-500-RWHP-Fast-102-big-cam-ported-heads-Cold-Idle
E38-E67-VATS-disable-guide
E38-no-start-issue
Z28-auto-swap
Cannot-change-vin-in-12633238-E38
LS9-with-trailblazer-SS-E67-cal
E38-idle-tuning
E38-E67-OS-compatibility-list
E92-VVE-axis-is-MAP_BARO-ratio
Custom-OS-5
E67-ECMs-Listing
PCM-Conversion-Information
How-about-a-transmission-tuning-tutorial!
Tool-to-help-tune-A4-shift-points
4L80E-Reference-Material
4L60E-Reference-Material
Improving-shifts-via-the-ECM
T43-E38-6L90-Shift-points-change
6L80-Reference-Material
need-B9021-for-01250003
Can-t-load-PIDS-for-BB-log
BBL-PIDs-V2
Recovering-Log-Files-From-SD-Cards
Setting-up-a-FSV2-from-scratch
Please-Read-Windows-8-Users-(USB3-xHCI)
serial-port-cable-that-goes-to-v2
Upgrading-from-older-bootblock-firmware
V2-A-D-Calibration-FAQ
Flashscan-to-LM-2-Serial-Cable
I-made-a-cable-for-BB-Logging
FlashScan-to-LC-1-Serial-Cable-Diagram
CVN-s-Explained
VE-Table-Interpolation-SpreadSheet
Hosting-an-Image
Collecting-links-to-scattered-material
E38-VVE-Setup-Guide
Idle-Tuning-Helpful-Info-Inside
Summary-Notes
RAFIG-PDF-Includes-all-of-SSpdmon-idle-info
B4105-how-do-i-link-this-table
New-Tuning-Tutorial-WeathermanShawn
joecar: find a suitable place to put these:
https://forum.efilive.com/showthread...ith-higher-IAT
https://forum.efilive.com/showthread...ent-parameters
https://forum.efilive.com/showthread...Transient-Fuel
