cannot get fuel pressure pid to show
no matter what, i cant get my fuel pressure pid to show...i am running it thru the egr wire but for now, the pid wont show up...anybody see the prob? My boost pid shows up fine
*UNITS
#Code System Abbr Description
PSI Imperial PSI "Pounds Per Square Inch"
None None "" "No units"
# Add slot definitions here
# See sae_generic.txt for more information on "SLOT" formats
#Units Low High Fmt Expression
*CLC-00-001
psi 0.0 20.0 .2 "(({SAE.MAP}>102)*({SAE.MAP}-102))*0.145"
*CLC-00-002
psi 0.00 100.00 .2 "({GM.EGRS}*25)-12.5"
*PRN - Parameter Reference Numbers
# See sae_generic.txt for more information on the *PRN section
#Code PRN SLOT Units System Description
CALC.PSI F001 CLC-00-001 psi Fuel "Boost"
CALC.FP F002 CLC-00-002 psi Fuel "Fuel Pressure"
