Attachment 19953
Here is the current tune file. Its not tuned just trying to get it to idle correctly. I sprayed the entire intake and throttle body with brake clean to see if I had any vacuum leaks but didn't find anything.
Attachment 19953
That was a pretty short log. But I did notice your IAC steps went to 0 and it was still idling at 1500 rpm. The engine will not be able to idle down to your desired idle speed if the valve is all the way closed and still pulling in 18 grams/sec of air. I would try closing the throttle blade and see if that helps lower the idle down. Shoot for 60 steps at hot idle. Air seems to be coming from somewhere.
Can you adjust idle with the DVT controls?
Attachment 19954
I knew I should have asked how long of a log I should have gotten. I have another one I took that I will post as well. If my IAC is going to 0 how would I adjust that? I thought that was B4401/B4402?
As far as the throttle blade, I checked that the cable was seated properly and I checked the set screw which at this point I backed it completely of the blade linkage. Something that came to my mind just now is I wonder if my throttle cable is just tight enough it has opened that butterfly and that is why I am getting that tiny .4% TPS signal.
DVT, I played around for a quick second to see if it would do anything. The only thing I got to work was doing the injectors on and off. I did not mess with it long enough to try throttle as my brain was confused on why it was idling so high.
I'm also starting to wonder if there is something up with the IAC. Something like maybe the bore is wrong size or no deep enough etc. I see there is a difference between ls1 for 98/99 and the 00/02 models.
Does your throttle blade have a hole in it...?
Did transmission die from low pressure...?
No hole in the blade, just a ls2 Holley 90mm tb out of the box.
No tranny didnt die from low pressure? Did I miss or overlook something
Sent from electronic life sucking device.
Your log had quite a few EGR codes. Is there any way it could be getting air through the EGR at idle?
