2 Attachment(s)
Timing table won
Hi there!
I have been having an issue with a 2006 5.9 where the timing table won’t move off of the 0mm3 column, it is commanding proper fuel and rail pressure, but the truck feels doggy and unresponsive. I will include pictures of the data log, playing it back in v7.5 shows that the 0.0 mm3 column is where the truck is following the table and won’t move past that, and the RPM moves across the outside column like normal. I am wondering if I am in some sort of engine limp/safe mode from a bad sensor? Or if I’m logging be wrong parameter? Has anyone else had this issue before?
Max
This is just a Scan tool -> Tune tool linking issue, the Scan tool is working and logging what the truck is actually doing.
Browse to "C:\Program Files (x86)\EFILive\V7.5\Configuration" and find the the <insert ECM codename>_link.cfg file for this ECM, open it and ensure the table links and units are set up properly.
