Can I copy .ctz files using file system
I have a .ctz file emailed to me but I'm running Linux (currently Mint 17.3). I'm a bit of a newbie to Linux, but I'm not afraid of the command line. I did install EFILive 8 using WINE and then found out about the USB issue. I've done a bit of searching and read some of the threads here but I don't see any solutions. dmesg does show the EFI AutoCal v2 so it is being recognized. It would be great if there was a solution other than a VM (not sure I know where a Windows CD is). Is there a way I can copy the ctz file to the AutoCal using the file system instead of EFI Live?
I saw some interesting posts about an API to use the Autocal without EFI Live but don't know if that is available. I'm a bit of a programmer, but mostly Java <ducks>.
