Post a screenshot of the PIDs tab (showing the pid CALC.NTK_AFX)...
Yes I did.
Just as I was going to screen shot my pids I double checked to see the pid parameters and now its valid!
I hope to test it later today.Attachment 19568
I tried it tonight and and stays on 11.1. I'm going to get a meter and double check voltage output of the afr monitor to confirm it's working.
I have confirmed aux output voltage from the afr monitor is working correctly. It reads 4.5v in free air and with the car running it was fluctuating between 1.8v-2.2v on my meter with an afr in the high 12s- low 13s.
When I connect to the V2 I still don't get any correct data when any one of the CALC.NTK_AFX.LAM, CALC.NTK_AFX.EQR, CALC.NTK_AFX.AFR. That pid just freezes up on a log.Attachment 19575Attachment 19574
I'm wondering if it will be easier to start over with a new calc. pid. I don't use and other analog inputs anyway.
Post your log file and your calc_pids.txt file.
Which V7 build version are you using (go Help->About)...?
Attachment 19576
I am using the calc pids file you posted.
Build 282Attachment 19577
Sorry, my apologies...
I posted a bad calc_pids.txt in post #16 above (was missing closing quotes and duplicated CLC-00-003)...
I have now corrected the calc_pids.txt and re-posted to post #16 above and here also.
Note: please log SAE.LAMBDA and post the log file, I want to see what it does.
Also, I think you should upgrade your V7 software to latest build (and if you have FSV2 then update V8 also, and FSV2 firmware also).
I an grateful for you time. Thanks for helping.
No change. The pid is froze
I checked for updates and firmware updates and it says I have the latest.
Sorry I can't seem to find the SAE.LAMBDA
