EFI Live V2/USB Comunication Problem
I can no longer communicate with the V2.
I think I have it narrowed down to a problem between the PC and the V2. I have installed the software on 3 different laptops now and it still will not communicate. When I plug in the USB connection the PC does not see the V2. I can not check the Firmware or load a tune. I get the message stating it is in Demo mode because it can not see the V2 (I am not sure why that keeps happening since I did register the product as the message states). I have also tried a different USB cable and it does the same thing.
The 4th led blinks for a couple of seconds when i plug in the USB Cable. It appears to be flashing a code. It flashes 4 time then pauses then 2 times. it repeats this 2 times then goes out. It appears to be flashing a 42 code of some kind.
Any ideas???
However, if I disconnect the USB Connection and only plug in the OBDII connector the unit powers and functions fine.
Thanks,
Cary
