I take it you have suitable supporting hard parts and hydraulic parts (shift kit).
If he does 3rd gear only, it should only strain the converter right? It'll shift 2-3 unlocked then lock a second later.
Joe, why wouldn't I keep the 120 if that's the speed I want the converter to lock at WOT?
Wonder if I need to 0 out table D1008?
Do you have any logs containing the pids VSS, RPM, TP, GEAR, TCCMODE, TCCSLIP, TCCDC, SHIFTLAST, TFMPRS, TFT...
keep the pid channel count to 24 or lower since we want to see highest sample rate.
