Page 5 for the cos#5...:fluffy:
on a side note...i wonder if running OLSD on the cos#5 could be tweaked alittle using the autoVE methods to fine tune the dry shots even closer???:cheers:
You could with a custom calculated pid. For instance if you are running 12.5 to 1 commanded afr, but you want 11.3 to 1 afr while spraying obviously the standard BEN pid wont work. So you would need to make a pid something like
calc.afr/commanded.afr-offset. In this case the offset would be 1.2.
what ever happened to this?
Or is doing a conversion to the 512kb better?
Man... i so want this BAADD... E85 plus nitrous would be killer.
Who is still interested in this?
