http://www.efilive.com/index.php?opt...111&Itemid=121
Send the relevant *.blx files to me at paul@efilive.com
Paul, I've just recently sent across the ones I requested (a couple of posts back) that are from today.
After looking at the blx files they all show the same problem. The ECM refuses to go into programming mode. At this stage, I don't know why.
I am in the process of uploading a new software version that contains new LBZ/LMM BBF flashing options. Those options can be used to reflash an LBZ or LMM engine controller using the FlashScan device in standalone mode.
It would be worth trying the new standalone BBF options to reflash your truck. That will help rule in/out a problem with the V7.5 re-flashing software.
Once the new release is available I can help you set up the BBF options. It should be ready in the next 24 hours.
Thanks Paul. Thought I fried the ECM. Look forward to the updated version.
I think we are talking the same problem truck here.
This was the one with a standard (non DSP) calibration flashed in to a DSP5 OS?
If yes, I looked over the DSP5 code this morning and I think if you just move your switch back to the position that uses the factory (non DSP) maps then the ECM might actually work correctly again. If that works then flash back in a DSP5 calibration and everything should be happy again.
I have been having this same issue. Twice in the last week. It will allow me to access and clear codes with my V2 but I can't read, log, or flash. I did find the last time I had it happen that I could flash a previous tune after I cleared the codes.
I haven't updated in 6 months but it seems the above problem occurs with the latest release as well.
A very similar thing happened to me today. I upgraded to the latest version of EFIlive, and when i went to connect to a truck, it stated PCM not detected. I know for sure i was able to connect to the truck before. I will try tomorrow with the old version of EFILive and see what happends.
