Beginner help with LML tune
I recently purchased EFI Live and V2. I'm trying to find help on tuning a 2012 Duramax LML. I've read the LML tutorial, the FAQs, and any other post that I could find, but I can't find any information on where to start for tuning an LML. It seems that everyone is very tight-lipped about this stuff. Could someone point me in the right direction?
Quote:
Originally Posted by
S Phinney
No disrespect intended but you need a very good understanding of the previous versions in respect to tuning. That will get you somewhat started. You can then throw most if that away and start over if you know what I mean by that. Do you plan on just mild tuning or delete tune img?
I appreciate the reply and any help. I'm not sure how to get a good understanding of the previous versions, when I just purchased the latest (v7.5 & 8). I do plan on just mild tuning, but I do want to delete DEF and EGR. DPF regens are rediculous (happen too often), and the mileage goes to squat. Basically stock otherwise, I do want to add a lift pump to save the remaining life of the brand new cp4 (Bosch fuel pump). Will probably do a cp3 conversion in the near future as well. No plans for bigger turbo or injectors, or anything like that.
I do know my way around most software, and I get comfortable rather quickly. I'm an owner in a software company, so I'm used to seeing different User Interfaces and adapting quickly. Not saying I'm genius, but I'm sure that I can learn and I'm willing to put forth the effort.
Again, any help is much appreciated, even if it's just pointing me in the right direction. At this point, any tutorials that I've read have been a small help, at best.
Two reasons are heat and turbo efficiency. The right combination makes more power, last longer and is more fun to drive.
Sent from my iPhone using Tapatalk
