September 2020, Beta 50 release 1
**Edit** New software now available, please see the updated post in the Software Updates and Installation Help forum
ATTENTION - BETA SOFTWARE RELEASE
We strongly recommend that you do not install the beta software over the top of your production systems. It is possible that the beta test software may fail and your production system may not be recoverable. lf you conduct a tuning business, please take the necessary precautions to protect your business. EFILive recommends beta testers use a separate FlashScan V3/V2 device (when installing the latest beta firmware) and only install the EFILive beta test software on a separate PC, laptop or virtual machine.
This beta update contains a new CSP switchable tune operating system for CMF controllers. It is an "early access" feature that is not intended for production use just yet. EFILive is looking for feedback on the performance of the CMF CSP OS. Please do not install the CMF CSP OS on remote vehicles. Only install it on vehicles in your workshop that you can recover easily if the CSP5 OS causes problems.
For users dealing with the V3 AutoCal products you must use this release and ensure that all devices have the firmware updated to the version in this release prior to being used on vehicles.
The current public release is available here.
Changes to V8 software
- Multiple *.cax8 files may now be defined for a single operating system.
- Provider details are now displayed per calibration so that the user can know if a calibration is provided by the EFILive software or via a third party *.cax8 file.
- Fixed CMB flash attempts that were failing with $0301 errors.
Changes to V2 firmware (V2.07.164)
Changes to V3 firmware (V3.00.046)
- Full control over user defined menus, colors, fonts background and splash images is now available. See \Documents\EFILive\V8\User Defined Menus\SampleCustomMenu.txt for more details.
Full Release Notes:
Version Numbers:After installing this beta release you should have the following software and firmware versions installed:
- EFILive V7 software: V7.5.31 To view the installed version, select Help->About (in the V7 Scan or Tune software).
- EFILive V8 software: V8.3.1 To view the installed version, select Help->About (in the V8 Scan and Tune software).
- FlashScan/AutoCal V3 Firmware: V3.00.049 (Sep 09, 2020).
- FlashScan/AutoCal V2 Firmware: V2.07.164 (Jul 30, 2020).
Download here:
Known Issues (in beta 49): Issue #1:
Providing custom splash and/or background images that are not exactly 240x320 pixels in size can cause the V3 device to crash while displaying the main menu - rendering the device unusable.
Workaround:
Update to beta 50.
Issue #2:
Reading and flashing via V8 pass-thru or V3 BBx fails.
Workaround:
Update to beta 50.
Regards,
The EFILive Team
