4 Attachment(s)
1998 Trans Am LS7 with Procharger 10 to 11 PSI peak. Thoughts about some fine-tuning
First time I've been able to tune consistently because it broke every 4L60E or build I put in. Now that the 4L80E is living, I got some hurdles.
1. I got some LTFT's going into WOT
2. Tip into boost always hits lean for a moment
3. 50 to 60% throttle (close to boost) was rich 10:1... I began to get away from that, but still struggling
4. I usually have KR in 1st gear, but barely any when rolling and hit from 2nd gear.
5. I finally got more consistent mid 11's for AFR. It seems to like mid to upper 11's.
6. I change from dual Walbros to single Hellcat and upgraded Boost referenced FPR with bigger bowl and 8AN return.. and 8AN Rails
Any advice would be appreciated. Here is some data.
Attachment 24574
Attachment 24571
Attachment 24572
Attachment 24573
