Converting 02 Z06 to automatic, questions...
I am putting in a 4L65E and will be controlling it via a Compushift Sport, but am trying to figure out which params I need to flash in the pcm to make it compatible w/the auto.
This is what I was given by RPM:
2 Blue wires will wire into the reverse light switch wiring at the transmission
2 Purple wires will wire to the lower clutch pedal switch so that the car will only start in park or neutral
For the upper clutch pedal switch the pink wires you will tie together so that your cruse will still work
You will need to turn off the codes for the reverse lock out and skip shift solenoids
Looking for thoughts as I complete this swap...
