I've got flashscan2, about to add a wideband in the mix. Which wideband are you guys using?
Im using a PLX with a circuit to interface with V2 (TTL to RS-232)
I'M using PLX
AEM and it sux!
dual LC-1's
Lc-1
Just hooked up my LC-1 to the serial input yesterday and works like a charm :)
I'm using a TechEdge 2J1 unit.
I did try a PLX and found that the analogue signal suffered a bit from earth off set errors, but using the serial interface fixes that. the Tech edge on the other hand has an earth reference in-put that adjust the analogue signal for any earth off set. Logging both the analogue and serial data shows them to be equal.
Simon.
<-- LC1 here
