1 Attachment(s)
autometer wideband
im running a autometer wideband and trying to get it to show AFR. it will show voltage but want air fuel. it is 0v=10afr and 5v=17afr. need help getting it to read correctly. ive tried putting a calc pids in the user config but not sure if im doing it right. idk if there is one all ready loaded into the program or not. ill attach the calc pid. help will be appriciated!!!
That should work, but add 2 or more blank lines after the end of the file.
make sure the file name is calc_pids.txt, move it to the User Configuration folder...
restart the scantool, goto the PIDs tab and look for CALC.WO2AFR, make sure it does not have a red X thru it
( click on the column heading of the Parameter column (i.e. click on the word Parameter) to sort on that column, each time you click again it reverses the sort order ).
thanks for the reply. i found it but it has a red x thru it
You have to enable the input pid too.
Worked liked a charm!!! Thanks everyone for the help!!!!!
