Duramax EGR block using EFILive?
I'm a complete noob to the diesel tuning, or actually car tuning in general. So, this question may be stupid to many of you.
I have been playing the the demo version of EFILive tune for Duramax. I noticed EGR can be control by ECM. With that in mind, wouldn't it possible to 'block" EGR by simply command the EGR to be close at all time?
Disabled diagnostic/monitoring table?
Quote:
Originally Posted by
dansdieselp
Yes. Minimum temp 300* and Maximum temp -40* Don't disable the diagnostic/monitoring table.
I've had to reflash the stock program in my 06 lbz duramax in order to pass emissions obdii check. Inspectors tell me the engine misfire and egr flow should be supported, but my scan still shows both NOT SUPPORTED. Could this be due to a disabled diagnostic/monitoring table? How would I check that and reverse it?
