So I was looking over some past logs and the PIDS for the Allison used to be valid. I have them logged. Have you looked into them any?
Post a log file.
September 30th, 2018
Bdirtymax
2 Attachment(s)
Here's a pair showing different A40 PIDS being logged that are not valid now. Current gear, last shift time etc..
October 1st, 2018
Blacky
Quote:
Which PIDs were valid but are now no longer valid?
Are you using V7 Scan Tool or the V8 Scan Tool?
October 1st, 2018
Bdirtymax
Paul,
I was getting a $0312 error trying to log tcm pids like Last shift time, output speed for next shift, current gear, commanded gear etc.. I just loaded them back in my V2 and everything is working now. Not sure what happened but problem solved.
October 2nd, 2018
joecar
Paul,
You re-programmed FSV2 BBL and now it works... ok, thanks for the update.
