So you do not have the LS2 intake (which is said to suffer from internal leaks)...
Quote: Originally Posted by joecar So you do not have the LS2 intake (which is said to suffer from internal leaks)... Correct, I have a L76 intake. A leaky intake would explain higher MAP or less vacuum than normal / stock.
