Hello. I have been tunning gm vehicles for quite sometime. I want to buy the Cummins upgrade. But is it to late to still have access to the tables required to delete dpf? Thanks
what color is you v2? if black you should buy a blue one as some dodge will not be supported on the black ones. and no you can still get dpf delete stuff
CAN based Cummins vehicles are supported on Black FlashScan V2 units.
Customers should be aware that if/when we do offer support for SCI based Cummins vehicles (2003-05) that these will ONLY be supported on Blue FlashScan V2 devices. In December 2009, we made a circuit board change to support that protocol.
EFILive does not recommend customers replace their Black FlashScan V2 device for the sole reason of SCI communications protocols until support is available.
Cheers
Cindy
