No worries... I replied in your other thread: Were-do-I-find-Ben-factor-LTFT-or-any-ben-factor-I-don-t-see-any-ben-in-my-pids
:secret:
Any more progress? Is there anything else I can help with?
We both got some stuff going on (particularly family stuff)... pretty soon we'll be spending more time on this.
In the meantime post a few logs and your calc_pids.txt.
That is a good idea you have... since you may not get perfectly zero analog voltage, you might try something like this:Quote:
*CLC-00-110
factor 0.5 1.5 .4 "iff({EXT.AD1},{CALC.EXT_AD1_WBO2.lambda},{EXT.WO2 LAM1})/{SAE.LAMBDA}"
factor 0.5 1.5 .4 "iff({EXT.AD1}>0.2,{CALC.EXT_AD1_WBO2.lambda},{EXT.WO2LAM1})/{SAE.LAMBDA}"
but it's still a clever idea (automatically selects the wideband connection mode).
That reminds me: I have to see if there's and abs() operator.
Do you have 1 or 2 widebands connected...?
can i help
i have a 2009 g8 gt
i have a innovate lc2 and bosh wideband
i ordered a null modem from efi live do i need this or use a different setup ??
what settings to modify for proper logging pe afm etc.??
what calc.pids text file should i use?
log which pids?
Digging up an old thread.
I know that it's been a while and people move on, so I'm not sure how much demand there is anymore for an E38/E67 Calc.VET but if people still want to try to get a Calc.VET working then I think that I may have found a way to do it.
To know for sure if my idea will work, I'll need two volunteers with basically the same engine, but with different cams. If you have time to do some logging and want to help, then post your engine specs and hopefully we can find two people with engines similar enough to get something happening.
Hi Statesman
My engine is out at the moment, keen to continue where we left off once fitted.
Likely new year.
I would be glad to help in any way I can. The only vehicle I have that might do a cam change is an E67 gmpp 525hp so I might be able to do a before and after on that one if it will help.
