1 Attachment(s)
Corvette C4, LS1 P1SC Procharger need tune
hi,
I need someone expert to tune my Procharged Ls1 Corvette C4.
It was running fine with 42lb injecotrs and I replaced the injectors by RC 750cc
and when modify the Injector flow rate to fit with the new injectors its running rough and lean and the AFR is 19 and above
I am not that much expert at the Efilive tunning program
I need a good tunner to modify my tune file and modify the VE & PE to fit to my application
engine : LS1 - 347
cam: 265/271, Lift .558/.563
Injectors: RC 750cc
Transmission: T56
Boost: 7-10psi
the attached file with 42lb injectors
could someone please help me on the subject....
http://www.youtube.com/watch?v=tP8Pv...eature=related
