I know you figured it out but for everyone else's benefit....make sure you spell EFILive correctly (Hint - there is no space between EFI and Live....)
Cheers
Cindy
Quick question just to verify this isn't just a "me" issue, I'm assuming that there are still a lot of tables yet to be generated in these LML files still, the reason I ask is because I noticed there isn't much under the "engine diagnostics" segment yet as far as being able to enable/disable codes from reporting......due to still being a beta type file?
Thanks! Looks great, can't wait to tune an LML with it!
There is no DTC tables because of the emissions defeat problem, we can't pick and choose which DTC's are available for editing, it's all or nothing, for the moment we have to chosen nothing.
But yes it is still early days, you'll notice some tables don't have descriptions, though the names should make it clear as to its function.
