Originally Posted by
Blacky
Try deleting the V7 registry hive. You can do that by:
Close all EFILive software.
Run "Regedit".
Locate the key: \\HKEY_CURRENT_USER\Software\EFILive\V7.5
Delete the V7.5 entry and all subkeys
Close Regedit.
Restart V7 Tune tool - this will recreate the registry entries with their original default values.
WARNING: That will revert all your EFILive software settings (such as colors, windows sizes, recently used folder names etc), back to installation defaults.
However, it is possible that one or more settings are faulty/damaged and could be causing the problem.
