Creating Custom PIDs - Custom Queries, Not Calculated PIDs
Is it possible to send custom queries onto the bus while logging data using EFILive?
I'm trying to extract some TCM data from a non-supported unit, and was wondering if I could create a custom PID that EFILive could then log. I have not yet done the work to identify the address of the TCM, or the queries that I need to send, but they will all fall within the realm of "normal" data that the TCM would be expecting to receive queries for.
I know you can create calculated PIDs using data from EFILive's built in queries (PIDs), but this isn't what I am after.
I may also use this to extract some data from unknown ECMs as well if it is possible. I expect all the root capability is there since this is essentially the function the tool performs, but is it available to the standard user, or only to the software developers? :)
Thanks for the responses!
