93 Camaro LT1 Converted to 24x with Torqueheads MAF questions?
Subject sums it up.
I've got the car running on a 411 PCM, its not firing on cylinders just yet and I did switch the 2-3 & 4-7 injector wiring along with the injector bank assignment adjustments. I'm assuming I'll need to do a crank relearn and I will here shortly. The 93 LT1 Camaro was strickly a 1-bar MAP, not MAF. Can I just disable the MAF by adjusting the high and low limits and then tune off the VE tables using the 1-bar? Or should I install a MAF?
Small update: The validate PIDs procedure in the EFILive scanner worked great and I have all the supported PIDs back. I played around with the IAC effective range and now the car purrs at 750rpm idle. I really need to get this thing running on COS5 so I can hook up the wideband and use AutoVE to dial in the tune. Thank you for all the help thus far joecar!
