i need help with injector pulse and timing tables. im new to efi but not tuning. engine is a 6.7l i have a cm849b. i have a 6.7 injectors 450% with body mods, dual cp3 kit. im having trouble getting it to idle.
Using dual cp3 controller or splitter harness ? If using splitter harness, youll need to cut ma table in half...
Idle timing should be around 0-2 degrees idling if using pilot injection..
Need to add to mA to table D0787 if using splitter harness 1.6-1.8x roughly normally. lower the number higher the pressure.
Hi thanks I’m running a ppe pump controller I’m gonna test main timing at 2 degrees tomorrow
