That's what it says to set them at in the tutorial. What would you suggest setting them to and why?
Try attached tune,out of range fixed.
Your settings weren't wrong,sometimes with out of range stuff you just need to change it to something lower than max limit and save tune,you can then usually open saved tune reset back to max limit if wanted,save tune again,reopen tune and hopefully nothing is out of range anymore.
Makes sense Thanks for the help!! still learning all the ins and outs lol.
Also your VIN is all zero's and B3647 & B3649 are set to lean out in the 95/100 columns. Looks like a bit of confusion between using lambda & EQ ratio.
I already fixed the VIN ill look at B3647 and B3649
Yes you are right that is wrong. now I am forgetting how to change the units from lambo to eq.
or do I need to adjust the numbers to be lambo instead of EQ ratio
edit,properties,commanded fuel values.
Just remember you will need to close and reopen your tune before the change will take effect.
Do as suggested above , then adjust as needed to suit what your using.
Ok this is what I have now. This rookies feet are getting wet lol. Attachment 14804
Thanks so much for the help!
